783 w/Hitec 555 and flapperons
Hello,
I'm trying to program my 783 tranny for a DLG with flapperons. I'm using a 5 channel Hitec 555 Rx. I've used the Sailplane program in the past with this type of setup just fine but I'd like to setup a launch preset on the snap roll switch. Is there a way to use the snap roll switch in the sailplane program? If I use the Acro program I can't use the flapperons because I don't have access to channel 6 on the Rx. Can you offer any suggestions? Thanks.
I'm sorry to say that I don't see a way to use it for any features on any channels. You could set up the ailerons in your own mix in ACRO mode in mix 5 or 6 to use channel 5.
hi shoe
make a new mix on mix6 or5
master aileron slave gear rate mix left+100 right +100
make a new mix on mix2 or 3
master gear slave gear up-100 down -100
in this case you inibhit gear swicht and have fully aileron on 555 right on ch2 and left on ch5
regards mirco
regards mirco
