10X Servo Channels 9 @ 10
RE: 10X Servo Channels 9 @ 10
All 9 channels are updated the same on the 9303.
No, the resolution is not the same with ppm or pcm. PPM theoretically has infintite resolution, however the positioning is not as accurate, so the servo never really achieves the position commanded by the system. PCM resolution is dependant on type (ZPCM = 512, SPCM = 1024) but is far more accurate than PPM.
