610ul vs r770s pcm receiver
NY
Just bought a new 2 meter sailplane & will use my 9303 tx. But wondering if the 610ul receiver will have enough range? If not I'll get another r 770.
Thanx
Greg
Thanx
Greg
RE: 610ul vs r770s pcm receiver
Some customers do use the 610 in sailplane applications, however if you are flying at long distances, or if you are in a noisy environment the 770 will outperform the 610 for range. Personally I would say if you are not flying at exteme distances from yourself the 610 would likely work just fine, otherwise I would stick with the 770.
