JR pitch curve
JR pitch curve
I have an ikarus variable pitch motor and prop assembly. I have set it up on heli mode. The receiver I am using is a jeti 5 channel, so the pitch must work on channel 5 (gear). I have mixed gear and pitch but I cant get control of the pitch curve. Adjusting the pitch curve has no effect on the pitch on the Ikarus motor and prop. Can I achieve this or do I have to put a 6 channel, heavier receive on.
Barrie
Barrie
RE: JR pitch curve
PCM9X
I have temporarily put a 770pcm receiver in have flown the plane today. Is going to take some practice..
I would like to know if what I asked is possible, to lighten the shocky a little.
Thaks Barrie
Thaks Barrie
RE: JR pitch curve
I'm not 100% certain on the 9X since that is a system we do not have in the US, however on the US 9303 which is similar, you can set up a pitch to gear mix and set the rates to 100% in pos 0 values, and do not activate any switches in the mix. Also inhibit gear in device select.
RE: JR pitch curve
Thanks Danny
I did that but it still doesnt give you control of the pitch curve at certain points.
Thats OK I will stick with the 770pcm at the moment.
Took it to a meeting tonight and drove it backwards around the floor. All were amazed
Barrie
Barrie
