JR 9XII Flaperon question
Hi Guys,
I have a JR PCM 9X2 radio, I just noticed yesterday on my CAP 232 that when I give left or right aileron, the aileron that is going up moves only about 50% of the travel available and stops while the aileron that is going down continues to go till full stick deflection !!! Weird, I checked to see if i have any mix or aileron differential applied by mistake and I have none ! Anybody noticed that ? Any solution ??? By the way the wing type is flaperon.
RE: JR 9XII Flaperon question
You will either need to inhibit the flap switch in device select, center your ailerons with the flap switch in the center position, or in some other manor set up the flaps in device select or the flap system to center your ailerons in the true center of the channel. It sounds like your ailerons are centered with the "flaps" deployed which is causing you to run out of servo travel.
