Throttle Cut on XP9303?
I'm moving from a Hitec Eclipse 7 to a JR XP 9303 (airplane). On the Eclipse there was an "engine cut" (throttle cut) switch that was easy to set up (also a "throttle hold"). I've searched all the PDF files at http://www.jrradios.com/Products/Sup...odID=JRP9241** and can not find a way to set a "throttle cut" up on the 9303. I'm sure it's simpler that what it appears, but the solution alludes me. A thorough search of the web, rcgroups, and rcuniverse, turns up no answer either. I'd like the set the "trainer switch" to be throttle cut on a gas airplane. How do it do it?
Thanks!
Thanks!
RE: Throttle Cut on XP9303?
Thanks Danny. I'm disappointed that JR's 2nd to highest tech radio doesn't have built-in throttle-cut and throttle-hold (desirable safety features), but it's other fine features make up for it. I'll program the mix you suggestion into each model that needs it. Thanks for the prompt reply. )
