10x flaperon
My Feedback: (12)
VA
10x flaperon
Is there any way to get flaperons to work with a 4ch receiver? I used one mix to mix out the rudder with itself. Then I tried to mix ch6 to ch4 to get the flap commands to operate ch4. It didn't do anything. I finally used a normal wing and and mixed the aileron to the rudder and it works, but I can't get the differential to work. Any ideas?
RE: 10x flaperon
No, flaperon uses channels 2 and 6. You can set up a mix to use channel 4 as an aileron channel like you said, but differential will not be available, you would have to use travel adjust or the dual rate function to set up differential.
