9303 How to turn off flap lever?
TX
Hi
I have set up my radio for an acrobatic plane with 2 aileron servos so I set the wing type to "Flaperon". I'm using the flap system to drive the ailerons into 2 "down flaperon" positions using the 3-pos flap switch. But the left side lever (flap lever?) also wants to control the flaperon positions and I'd rather not have this control messing with the ailerons.
All of the "devices" on the system page are set to INH, except for flaps which are assigned to the flap switch and "SYS" mode. I don't see anywhere to disable the lever. I even tried setting the trim step for AUXT and FLAP to zero with no success.
How can I disable the left lever?
Clark
Clark
RE: 9303 How to turn off flap lever?
In device select, rotate the roller until the TRIM line under flap says OFF, it defaults to ON. If it remains active after setting that to OFF, there is something else activating it such as a program mix.
TX
Thanks! Mix 6 was LLVR->FLAP. Don't know how that got set, maybe I copied it in from a sailplane program or something...
Clark
Clark
