Tx field charger ?
My Feedback: (12)
MD
Tx field charger ?
Danny: Just got the XP6102 and would like to know how to field (Fast) charge the Tx batts, knowing JR charging plugs are reversed by color, what should I use? THanks again,Mikel-T.
RE: Tx field charger ?
The polarity is reverse of other brands, the center pin is negative with JR so you must make sure the polarity is correct or you may damage the transmitter. From there, just make sure you charge at 1 amp or less.
