10x problem
My Feedback: (9)
NC
10x problem
Hi
Today I was cought in a downpour with my JR 10x.
Later on in the day, when I pucked up the radio from inpound, the digital trim on the rudder moved by itself to full left without touching the trim switch. After that the trim on the rudder would not work at all.
Should I send the radio in for repair to fix the trim? Or can I fix it myself? (the radio is 5 years old). Or should I have it repaired and replace the onboard battery too?
Bill
Bill
RE: 10x problem
It sounds like something may be shorted out or corroded inside the system. I would recommend sending the system in for repair. It would be a good idea to at least have the lithium battery checked as well if it has not been recently.
