Re: 6102 radio air
CA
Re: 6102 radio air
I have a 6102 radio that I am going to use with a H9 P51 1.50 plane and I want to mix the flaps with elevators. I tried to program the radio by using MX1 but when I select the switch (upper right flap switch I get no movement from the elevators (down) What am I doing wrong. Is there more places to program this function.
RE: Re: 6102 radio air
I assume that you are wanting some elevator compensation when the flaps are deployed? The easiest way is to set the amount of elevator you want with the flaps in the flap system menu. The other way would be to use a program mix, program mix 1 should work fine, just mix flap to elevator, assign the switch, move the switch to the 'on' position, and set the rate as needed.
