Prog mix for idle-up on XP9303
My Feedback: (39)
GA
Hi Danny,
How would you go about setting up an idle-up function in one of the programmable mixer on the XP9303, so when you flip a switch to on the engine RPM increase a bit at idle during flight and return to low idle when off?
RE: Prog mix for idle-up on XP9303
The easiest way would be to set that up in the throttle curve function, set up 2 different curves after you've assigned the throttle curve function to a switch. To set it up in a mix, you would set up a throttle to throttle mix, and set the rates as needed.
