XP6102 info
XP6102 info
Here are a few questions:
Does the 6102 have any timers?
Can it be interfaced with a computer and how, for flight simulation (FMS)?
Can it be connected to a Futaba radio for flight training - Buddy Box?
Does the positive shift Hitec receivers work with the 6102?
RE: XP6102 info
It only has a total model timer. It can be used with sims assuming you have the proper adapters and program that will work with JR systems. A Futaba system can be used as a slave with JR as the master with the Hangar 9 Trainerlink. Yes, they should work.
RE: XP6102 info
Danny,
Thanks for the info!
Can I us the model timer as a flight timer?
Do you know if the FMS simulator is compatable with JR?
Thanks!
Thanks!
RE: XP6102 info
No, the model timer is only a timer to count the total model time.
I don't have any knowledge or info on the FMS sim, assuming you can get the proper adapters it should work, but I have no information on what is needed.
TN
RE: XP6102 info
I can not believe JR would produce a transmitter without a flight timer!!!!????! What a sales killer!! Do the people designing these things fly?? Apparently not! The thing has a clock in it... oops we forgot to program in the flight timer.... maybe no one will notice!!?
unfreekingbelievble
unfreekingbelievble
TN
RE: XP6102 info
i like a flight timer and the last radio i bought a 7202 doesnt have one either didnt know it till is was too late i have a 8103 and use the timer a lot
