8611 Centering problems
My Feedback: (54)
FL
Hi Danny.
I just got my 8611 back after the servo case upgrade.
I hooked it up last night (It's the rudder servo on my Extreme flight Yak-54) and now the servo is not centering correctly.
I know I can send it back, but I have already been grounded because of this servo for 6 weeks.
And you know our flying season is coming to an end.
Any other ideas or suggestions.
Mat
Mat
My Feedback: (54)
FL
RE: 8611 Centering problems
I give full left rudder, the rudder doesn't come back to the exact center. It's a little bit off to the left.
Now I give right rudder, the rudder comes back to the exact center.
Again left rudder, same problem
Thanks.
Thanks.
My Feedback: (54)
FL
It is off substantially. I don't think it's safe to fly the plane with the rudder off to the left so much.
Is there a way I can fix this problem without sending the servo to you. I have already wasted 5 weekends getting the servo case upgraded and we are running out of flying weekends.
Thanks.
Thanks.
My Feedback: (54)
FL
Hi Danny.
I rigged up a test servo arm using a long carbon fiber rod taped to a servo arm. This gives me a more accurate reading.
The centering problem does not appear in this case. Why is it when I hook up the rudder, the rudder does not center.
Thanks.
Thanks.
