JR 9303
ON, CANADA
JR 9303
Hello, I was wondering if I can use a standard FM reciever with the new JR 9303 because I don't want to put a PCM reciever in my 40 sized planes and electric foamy I would rather go with a small cheap FM reciever like Hitec Micro 4 channel reciever for my foamy. And the 9303 says its S-PCM and PCM and not FM.
WA
RE: JR 9303
They both transmit in FM (frequency modulation) as opposed to AM (amplitude modulation). There are AM radios around but yours is FM. A simple minded answer to your question is that one, PPM, indicates servo position with an analog value and the other, PCM, indicates servo position with a digital value. There is of course more to it and if you are really interested there is a paper on the Torrey Pines Gulls web site that will answer all your questions. It is titled "Everything You Never Wanted To Know About Radios". Here's the link http://www.torreypinesgulls.org/
Good Luck
Good Luck
WA
RE: JR 9303
Not sure as I only use JR. However, I don't think so. JR and Airtronics use the same encoding (believe it is positive shift) for the pulse stream from Tx to Rx while Futaba, Hitec and Tower use a different encoding (negative shift). I may have the positive/negative backwards. So, you should be able to use Airtronics receivers with your Tx but not the others.
My Feedback: (12)
VA
RE: JR 9303
Hitec makes each one of their receivers for both pos and neg shift or is capable of being switched from pos to neg with a jumper. Just make sure you buy the one for JR which is pos shift.
