JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
347 JR Radio
Old 10-10-2005, 10:10 AM
cassidy
Default 347 JR Radio
Can I use the 770PCM receiver with this transmitter?
P.C. Ryan
Old 10-10-2005, 05:16 PM
Mac_Man_UK
Mac_Man_UK's Avatar
Default RE: 347 JR Radio
Fraid not..... the 770 uses "S" class PCM ( 10 bit resolution 1024 steps ) whereas the 347 only ever used "Z" class PCM ( 9 bit resolution 512 steps).
The SPCM started with the X-388S Transmitter.
[8D]
Old 10-22-2005, 06:21 PM
Rate1
Rate1's Avatar
I got disturbance/interferance on my maiden almost lost my plane, using TX JR x-347 with RX Graupner/JR Varioprop 14C (Best. Nr. 3856). The testpilot think I should get myself a new RX considering the old one is too old and prob was the cause for the experienced twitches. Wich RX do you recomend me if I want to take full advantages of my old 347?
Old 10-22-2005, 06:35 PM
Mac_Man_UK
Mac_Man_UK's Avatar
The problem is that the older Z class PCM is no longer in production. I think we still have some stock of the ZPCM receivers but they are expensive in comparison.
Correction.... have just checked the stock level and we are out of stock. I can try and find out on Monday if we can get more of these but I am extremely doubtful.
The current range of JR receivers in PPM mode have the NER700 7 channel receiver or the NER549 9 channel. You could try getting a replacement ZPCM receiver on the second hand market or look at upgrading to the 9XII Transmitter.
Cant think of any other option,
[8D]
Old 10-22-2005, 06:44 PM
Rate1
Rate1's Avatar
Ok, thank you for your responce. I will have to think this one over...
C.
