10 sx
My Feedback: (99)
TX
10 sx
hi dan can you tell me what is the difference between the 10 sx & 10sx11& 10x. thinking about buying a used 10 sx.
btw what would be the cost for a tune up and what do they do ???
thanks dennis
thanks dennis
10 sx
Dennis,
I have a 10X and a buddy has a 10SX. One of the differences that we have notices is the 10X has a mix for dual elevator servos, the 10SX does not. I believe that it is mostly in the programming but I have been told that a 10SX cannot be reprogrammed by JR to a 10X.
My advice, is even though the radios are similar, there are enough differences to make it worth your while to hold out for the 10X. I believe that you can get a brand new transmitter only for around $650 with the module and case.
Andy
Andy
My Feedback: (99)
TX
10 sx
andyf
i was thinking about buying a new 8103 but this 10 sx came up thought it was a better deal. going to 33% plane and it has 2 servos per surface was wondering witch radio would be better.
thanks dennis
thanks dennis
10 sx
Dennis,
If you are not planning on flying helicopters, I'd say the 10SX is better than the 8103 - easier to program more options except that you can setup the 8103 for helicopters. SX or the X has to be dedicated to airplane or helicopter.
I had the 8103 as my first new radio after getting back in the sport. I had an opportunity to get the 10X and have never regretted.
You will most likely have to use a "Y" to connect the servos.
Andy
Andy
10 sx
The differences between them are mainly programming differences, and additional features in the 10X. Also the 10X has a thinner and more ergonomic case than the other 10 series radios. But the 10SX is certainly a good system. The cost for a check out really depends on if there is anything that needs to be done, but I would guess the average charge for a check up and tuning is around $20 to $30, but this does vary each way.
