xf622 questions
xf622 questions
Hello, I have recently got back into rc after a break of a few years. Just before I took said break, I purchased a xf622. It has never been used and is still new in box. Only thing is I removed the manual when I purchased it and have misplaced it. Any idea how I can get a copy of the manual. Secondly it has been sitting with dead batteries ever since, while I do plan to replace the batteries, will this cause a problem with the radio computer wise? Lastly, does this radio meet todays standards or do I have to have it upgraded or tweaked somehow? Thanks.
RE: xf622 questions
You can send an email request to "[email protected]" and we can either email you a pdf file of the manaul, or we can mail you a photocopy of the manual if you provide your mailing address. It shouldn't cause any problems if the battery hasn't leaked or corroded anything. It is possible that the lithium memory back up battery may be drained as well. You can send it in for a check up, or if you decide to use it, it is possible that you may loose any programming in the system while it is off. Yes, the system meets todays standards for operation.
