9303 flap switch for mix?
NY
I like to have spoilerons switched by the flap switch going up, and flapperons on the flap switch going down On my 8103, this was accomplished with the elev-flap mix, and another mix assigned to the flap switch.
Because the flap switch has 3 positions, this gave me "off" in the center, which I like. I can't figure out how to do this on the 9303.
The basic problem I'm having is I can't seem to assign the flap switch to any of the 4 switches controlling mixes. I thought the device select would allow any switch to act for any other switch function, but I can't get it to work. Please help.
RE: 9303 flap switch for mix?
Your best bet would be to activate flight modes in device select, if you want it on the flap switch that is one of the options. Then you can assign your elevator to flap mixing on to the flight mode of your choice.
