jr 9x smoke on throttle throws off mixer switch
hi danny a
could you help me programe my pete tindal smoke system on my jr 9x
i want it off my mixer switch linked to my throttle
i am useing my gear switch on my choke lever
all the best alansh
all the best alansh
RE: jr 9x smoke on throttle throws off mixer switch
You should be able to set up a throttle to the aux channel you are using for the smoke mix, assign the mix to the mix switch, and then set the rates as needed for the system to work.
