6102 using expo on rudder and throttle
TX
I would like to add expo to my rudder and throttle. Is this possible with the 6102? I have figured it out for elevator and ailerons.
Any suggestions?
Thanks for any help you can give,
dp
Any suggestions?
dp
RE: 6102 using expo on rudder and throttle
- include the rudder on one switch -with aileron and elevator - then -as I recall -you can add expo to it
the throttle servo tho -is not setup for this .
In the switch select function, select D/R to COM on the switch of your choice. Rudder dual rate and expo will then be available. There is no option for expo on throttle.
