Jr 8103 mixing question
My Feedback: (28)
IA
I have the newer 8103 running two elevator servos on 35% extra can i with the 8103 when mixing one of the elevator servos reverse one of the servos with the radio or do i need to i need to reverse the servo manually or with a programmer these servos are Hitec digitals??
You can reverse a servo for the second elevator provided you mix two channels together. You would use servo reversing for this. If you need some help programming this, send an email to [email protected] requesting the Air programming guide for the 8103 and it should assist you in setting this up.
My Feedback: (28)
IA
Thanks for the reply i have the original program manual that came with radio is this sufficient to use for programming the mix as you spoke of ref servo reversing thanks Bruce
