V-tail function on x-378
Hi Danny,
I have a Great Planes Viper with a V-Tail and need to get V-tail mixing happening. I have a X-378 Tx and use r700 slimline Rx.
I have done flaperons before and assume v-tail is similar but I can't make head or tail out of the manual and no amount of frigging around with the settings has yielded and results.
If you (or someone) can provide me with a simple, step by step guide to setting up v-tail mixing on x-378 transmitters I will be forever greatful.
CHeers!
Zeek
CHeers!
Zeek
RE: V-tail function on x-378
The easiest way would be to use glider mode and activate V-tail. The other way in acro mode would be to set up 2 program mixes in mixes 5 and 6, set up an elevator to rudder, and rudder to elevator mix, and in both mixes set the rates to 100%.
