8311 replacement gears
Danny,
I want to replace the intermediate gears in an 8311 servo with those from an 8417 as I understand that speeds
the servo up considerably. When I went to order them I see you have two replacement gear set listed for the 8417,
JRPSG8417 and JRPSG8417H. Would you tell me what the difference is between the two and which ones I should be
using in the 8311. Thanks for your help.
