Duel conversion recevers.
Danny.
I am now useing a JR 950 receiver in a 35% Extra, have had no problems at all. I am doing a 35% Yak now, with JR's ABC&W filtering system is it worth going to DC, and what is the advantage.
Thanks.
RE: Duel conversion recevers.
IF you aren't having any problems, there would be no advantage. In some cases dual conversion receivers such as the R945 and R2000 will outperform single conversion receivers, and in other cases the single conversion receivers like the R955 will outperform the dual conversions. Many variables such as aircraft layout and set up and noise in the area will dictate which will work better, however in most cases, both work equally well.
