Jr PCM10
Jr PCM10
Hi Danny I just got a PCM10 transmitter to upgrade my X347.Now I have all JR equiptment.The transmitter works perfectly how ever the touch screen display is not as bright as my X347 is this normal or can it be improved on.Arthur Pelham
[email protected]
[email protected]
Jr PCM10
There is a contrast adjustment for the screen. You have to remove the back half of the case, and there are 2 pots that you can turn. You will need to rotate the one closest to the center of the transmitter. You can verify this is the correct pot by touching the pot with your finger, and the screen should go black with the transmitter on.
Jr PCM10
Hi danny I removed the back and turned the pot and it dakened the whole display I the tried the other pot and it lightened the back ground it now is perfect thank you for the information and the speedy reply.I am hooked on JR, Geminni
