Spektrum Problem
Spektrum Problem
Having a problem with my M11 Spektrum system. When I power up the Truck, the steering servo will jump to the extreme End Point then jump back to neutral position. My initial binding to receiver was set with neutral steering as fail safe conditions. I have even tried a different steering servo with same results. It seems to work okay after finding neutral. Any suggestions or ideas on what the problem could be ?
My Feedback: (33)
RE: Spektrum Problem
Did you check the antenna wire on the module that plugs into the radio ? Some modules came with the wire ran on top of the circuit board instead of under and routed on the top side.
