6102 flap switch
My Feedback: (10)
FL
6102 flap switch
i need help with my 6102 tx. how do i null the switch for flap hover pitch. i set flaperon to work ok. but if i touch the flap switch the ailerons will either rise or lower, dont want this. want to kill the switch, the manual leavs a lot out.
RE: 6102 flap switch
Go the the flap system menu and clear the flap value. The digital trim lever will still operate as a trim however, and there isn't a way to change it from operating as a trim lever.
My Feedback: (10)
FL
danny that what i tought so i glued it in the center that prevents it from moveing. but i cant find flap system as the book shows it, is it worded a different way?
If in switch select you have flap lever selected, flap system won't show up in the menu. I would suggest to select a switch for the flap, then going to flap system and clearing it. That will leave the rocker as only a flap trim, rather than giving you full travel.
