JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Ppm Receiver ---pcm Receiver
Reply
Old 12-11-2002, 10:13 AM
francois118
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ppm Receiver ---pcm Receiver
Danny,
I have the 649 PCMS receiver and the R600 PPM receiver. I programmed my 3810 Tx using the PPM receiver on one of my planes. On a later stage I decided to use the SPCM receiver for the same plane.I changed the modulation of my tx to PCM.What I found was that I had to reprogram my tx in regard to the aileron,I had to go back to factory settings and had to readjust the servo linkage at the servo.
Is this normal ?
Thanks for your help.
Francois
francois118 is offline
Old 12-11-2002, 01:51 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just changing the modulation should not do that. If you went to model selection, or accidently reset the settings on that model, that would happen. But just changing the modulation should not change the settings.
dsnyder is offline
