JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Jr Recievers
Old 04-08-2006, 04:21 PM
f8f2ken
My Feedback: (54)
Default Jr Recievers
I was wondering what your receivers are compatible with I just picked up 2 of JR recievers has part of a trade a R770s and R700 I have futaba and hitec radios
Old 04-08-2006, 05:17 PM
jess24845030
Default RE: Jr Recievers
Hi mate i have used all kinds of recivers and you will be fine as long as they are not duel coversion type but you must use the cystals of the make of transmitter you are using hope this is use to you
jess
Old 04-10-2006, 09:26 AM
dsnyder
dsnyder's Avatar
JR receivers are not compatible with Hitec or Futaba systems.
Old 04-13-2006, 03:51 AM
Piet Le Roux
Piet Le Roux's Avatar
Jess,
The Futaba, Hitec and Towers are Negative shift (carrier - 5 Khz)= ON. The Airtronics and JR are Positive shift (carrier + 5 kHz)= ON. Carrier only is OFF for both
Old 04-16-2006, 07:35 PM
cassidy
You can use the JR receivers with the HITEC or AIRTRONICS transmitters that let you chose to use negative or positive. This is accomplished by making a choice in the programming.
Old 08-13-2006, 03:56 PM
bloomy
can I hook up a JR reciever to futaba servos and how do you hook it up to a speed controller?
Old 08-14-2006, 09:29 AM
dsnyder
dsnyder's Avatar
Yes, you can shave the tab off of the Futaba connectors to make them fit JR. To install a speed control, most plug the speed control into the throttle channel.
