JR G500T gyro - Set up problem
Danny,
while setting up my helicopter, today, I was not able to limit the travel of the rudder servo using the Servo Travel Limiter existing on the G500T. The limiter is just not responding, doesn't matter for what direction I turn it.
Can you tell me what is happening and how can I adjust the travel ?
The radio I'm using is a XP9303.
RE: JR G500T gyro - Set up problem
Try holding the stick all the way over and rotate the limiter. If it moves the servo, it is working. If it does not, it sounds like there is a problem with the gyro and I would recommend sending it in for service.
