vortex speed brakes w/10x
My Feedback: (9)
NC
Hi
I have a bt Vortex with dual rudders, how do the mix so I can pull both rudders in upon landing to act as speedbrakes using the snaproll button on the 10x Radio?
Bill
Bill
RE: vortex speed brakes w/10x
First I'll assume that you have dual rudders set up in a mix, mixing rudder to an aux channel, rates set at 100%, and master set to INCL and trim turned ON. After this you'll need to set up 2 mixes, first set a rudder to rudder mix, set an offset holding the rudder stick over one direction, then assign the mix to the switch, and then set the rate holding down the switch. Then set up a mix, mixing the aux channel to itself, set an offset in the mix, assign the mix to the switch, then set the rate to be double the rudder to rudder mix, but opposite (- instead of + or vice versa).
