can you use futaba sevos w/ jr rec and trans
can anyone tell me if this is possible. Also wher should I balance my plane at it is a magic plane w/ a .46 engine
RE: can you use futaba sevos w/ jr rec and trans
Yes, they should work, you will need to shave the tab off of the connector, and bevel the corners on the opposite side of the plug to get them to fit into JR. You'll need to contact the manufacturer of the aircraft for CG information.
