JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR xs3 and a sail winch servo
Old 04-30-2006, 04:50 PM
arr4ws
Default JR xs3 and a sail winch servo
i own a jr xs3 . I use it only for sailboats. I just bought a sail arm , but it seems i cant setup the right amount of travel i need , my servo is a hitec hs-765 hb .
How do i setup my xs3 so i can get the maximum of travel my servo can give me
Old 05-01-2006, 09:30 AM
dsnyder
dsnyder's Avatar
Default RE: JR xs3 and a sail winch servo
You can increase the travel adjust of the channel you'd like. Once it is at the maximum, that is the max output you will have with the servo being used.
Old 05-01-2006, 09:32 AM
arr4ws
you cant use the total travel of the servo? i did increase the travel and i found it pretty small compare to what the servo could give me...
Old 05-01-2006, 09:36 AM
dsnyder
dsnyder's Avatar
Yes, you can, once you increase your travel adjust to the maximum.
Old 05-01-2006, 09:37 AM
arr4ws
ok thanks much , ill try it tonight and ill let you guys know
