9303 Throttle Cut?
RE: 9303 Throttle Cut?
You can either go to the throttle curve function, set the curve to a switch, and set the curve in one switch position to be flat at idle etc, or you can set up a throttle to throttle program mix, assign to a switch, and set the rates as needed.
In most cases the throttle curve would be easiest since all you do is assign the switch and set the curve, and don't need to set the mix up. Outside of that though, they are both pretty similar and neither is overly difficult.
