9303 Memory Lock?
9303 Memory Lock?
I've recently had a very strange problem with my 9303. After charging, I tried to turn my transmitter on and it wouldn't power up. I knew I had probably blown the fuse somehow. After replacing the blown fuse, the memory seems to be "locked." If I change anything in any of the programs and turn off the radio, it will revert back to how it was last saved before that ill-fated charging attempt. Also, if I switch to a different model in the transmitter and then turn the transmitter off, it will switch back to the model it was on when the fuse blew. Has any one ever heard of this or have a solution that I can try to "unlock" the memory? I will most likely have to send it in to Horizon, I know, but I'm curious as to what this might be and if it was a problem with the charger or the transmitter that caused it.
Thanks for your time,
Clint
Clint
My Feedback: (15)
CO
RE: 9303 Memory Lock?
Thanks for the reply. I'm planning on sending it to Horizon on Monday; again, I'm mainly just curious about what happened -- I've never heard of this either.
-Clint
-Clint
You probably need to supply more information about the charger being used, the charge current level etc, before anyone can make any sort of a guess as to what happened.
