Gyro Mounting
Gyro Mounting
Does Gas engine vibration affect Gyro's operation. Should they be mounted so they will not vibrate, or is the supplied double sided tape ok.
RE: Gyro Mounting
Yes, vibration will affect gyro operation. Gyros should be mounted only with a shock absorbing double sided tape. The supplied tape w/ a gyro is good to use.
