JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
8103 programing
Reply
Old 12-24-2002, 07:03 PM
hatman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8103 programing
I am having a problem setting my transmitter to run 2 servos on a split elavator on the aux & elavator on the reciever Is there an easy way to do this I am frustrated
hatman
hatman is offline
Old 12-26-2002, 06:11 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the programming that will need to be done. If you have any further questions please let us know.
Dual Elevator Servo Set-Up
Now we will set up the elevators, so that we will have channels 3 and 7 working together. You will plug the right elevator into channel 3, and the left elevator into channel 7. Press the up key till you get to mix 5 or 6. We will use 5 or 6, as they are including mixes, meaning the elevator trim lever will operate both channels. If you do this mix on any other mix, the elevator trim will not work the second channel. Press the + key and change the first channel until it says elev. Press the channel key over to the second channel. Press the key to change the second channel to SPOI. Make sure that beside SW: it says ON. If not, press the select key till the arrow points at SW, and press the + key to make this say ON. Press the select key till the arrow points at Rate: and make the percentage 100% by pressing the + key. Then move the elevator stick, and the arrow will move to the 0% in one direction of movement. Make this 100% also with the + key. Now we have the elevator working on both channels, but the aux 2 knob will operate the second channel. To eliminate this, will use another mix. For this mix, I would use mix 3. Press the DN key to get to this mix. Once at the mix, press the + key till it says SPOI for the first channel. Press the channel key so that the second channel is underlined. Press the + key and make the second channel is SPOI. Then press the select key till the arrow points at Rate. Press the key till it says -100%. Then rotate the aux 2 knob, which is on the top left hand side. Rotate this until the points at the 0%. Press the key till it says 100% also. This completes the set up of the elevators.
dsnyder is offline
Old 12-26-2002, 06:55 PM
hatman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANK YOU VERY MUCH
HATMAN
hatman is offline
Old 12-26-2002, 09:22 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem!
dsnyder is offline
Old 12-30-2002, 04:20 AM
Ronbo
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Danny,
thanks from me too! I had the same question for dual elevators. your setup let me free up mix 1 for other uses!
i printed it out and will stick it into my 8103 manual.
glad i clicked on this thread!
Ronbo is offline
Old 12-30-2002, 03:10 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem! Glad it helped you out!
dsnyder is offline
