JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 7202
Old 06-27-2006, 05:52 PM
5150flyer
Default JR 7202
I currently own a JR 8103 and am in the market for a new computer TX. I like many of the new features of the 7202 and it appears to be more user friendly. However, is the software less capable? I don't want to loose too many features. I only fly aircraft: IMAC, pattern and 50cc giant.
Old 06-28-2006, 08:43 AM
dsnyder
dsnyder's Avatar
Default RE: JR 7202
The software is very similar to the 8103. Are there any particular functions you are looking for in a system?
Old 06-29-2006, 01:32 PM
5150flyer
Default RE: JR 7202
Quality materials, fit and finish, easier to use software, synthesized, same features as 8103 including timer count down. I like quality TX's that are easy to use and that is why I have always bought JR.
Old 06-30-2006, 09:00 AM
dsnyder
dsnyder's Avatar
Default RE: JR 7202
It is a very quality system. It has most of the features of the 8103, plus some new features. It does not however have a timer function.
Old 07-04-2006, 07:31 AM
skorman
Default RE: JR 7202
It is quite amazing to me that JR could leave out such an important and simple feature like a timer in a replacement for the 8103.
Old 07-06-2006, 06:01 PM
macr0t0r
Default RE: JR 7202
I am more interested in knowing if it will support both positive and negative shift Receivers (like the EVO and the Polk Tracker). Just get a stand-alone timer to clip on the antenna. It's easier to see and use than a built-in one.
Old 07-08-2006, 08:25 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Default RE: JR 7202
Is the new 7202 going to be in the 7200 MHz range or 2.4 GHz? I have just gotten into gas and looking for a new radio. Also, I didn't read anything about the radio having digital trims.
Old 07-08-2006, 10:41 AM
Mac_Man_UK
Mac_Man_UK's Avatar
Default RE: JR 7202
From the pre-production version I have, it doesnt support the opposition's alternative shift.
It works on the standard RC Bands ie 35 MHz, 72 MHz and I would imagine that for the relevant areas, 36 MHz, 40 MHz, 41 MHz and possibly th 50MHz band. It has digital trims.
When you power up, the set prompts you to confirm the channel number you wish to operate on, otherwise it doesn't transmit. You can change the channel number in the System setup.
Old 07-10-2006, 06:05 PM
KGSS28
Default RE: JR 7202
is the 7202 out ? the page on Horizon has gone from due early Aug To backored
Old 07-11-2006, 09:01 AM
dsnyder
dsnyder's Avatar
Default RE: JR 7202
They are not shipping yet, but should be shipping in August.
Old 07-11-2006, 07:05 PM
KGSS28
Default RE: JR 7202
have you gotten a look at what programing and features the 7202 has I would order today if I knew what it was going to have in it ?
Will the dealers get the first ones ?
Old 07-12-2006, 08:45 AM
dsnyder
dsnyder's Avatar
Default RE: JR 7202
Yes, I've used the system quite a bit. Generally dealers get product before we ship to consumers directly.
Old 07-12-2006, 11:33 AM
KGSS28
Default RE: JR 7202
could you tell me if it will support dual elevator servos and does it have throttle curve in the airplane programs ?
Old 07-13-2006, 12:42 PM
dsnyder
dsnyder's Avatar
Default RE: JR 7202
Yes, it is capable of dual elevator set up. There is not however a throttle curve function in aircraft mode.
Old 07-17-2006, 06:01 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Default RE: JR 7202
Deleted.
