JR X-2610 radio system
Danny, I am in the process of purchasing a JR X-2610 radio system. I have tried to obtain information about this type of radio, without any success. Can you please assist me with this problem, and tell me what you think about this system. I am living in South Africa.
RE: JR X-2610 radio system
In the absence of the Guru, I'll answer this one.
The 2610 is the equivalent of the 6102 with a few minor differences. It is a "Entry Level" system which has a good track recors. There are a few things lacking such as a countdown timer but thats a minor peeve.
The specs for the 2610 can be found here... http://www.macgregor.co.uk/radio/2610.htm For an addendum sheet showing the differences between the 2610 and the 6102 look here.... http://www.macgregor.co.uk/faq/Transmitters/X2610.pdf
Hope that helps, if there is anything specific, just ask and I'll see what I can do to answer the query.
Hi Tony,
No mention is made as far as transmitter power, deviation and bandwidth; surely this can not be the same as the American version?
Hi zs4lr,
Normally this info is not needed by the typical flier, all they want to know is what functions / mixes / goodies the shiny plastic box has got..
This Technical Info is standard throughout the UK for any Tx unit.....
Tx Output 100mW Max ERP
B/W 10 KHz,
JR uses +/- 1.8KHz Deviation, no doubt the other manufacturers are similar.
Does that help ??
B/W 10 KHz,
Does that help ??
Thanks for the info Tony but what worries me is that for 35MHz no specifications have been put down on paper by JR. I have done extensive tests on JR equipment and have found the following:
The deviation is about 3.5 KHz positive (+3.5 KHz) and the bandwidth is about 8 KHz (severe clipping accrues above a deviation of 4 KHz). Apparently Futaba, Hitec and Tower Hobbies uses negative shift. Airtronics and JR uses positive shift, nobody uses +- deviation. The transmitter puts out between 300 and 400mW into a 50 Ohm load but considering that the antenna is less than a ΒΌ wave and hand held, it probably radiates about 100mW.
To zs4lr
I see that you also live in South Africa. Maybe you can help me. Have you bought a JR X-2610 radio system recently, and if so, what do you think about it.
Thank you
Thank you
No, I have a much older JR computer radio, but it is very popular at my club and every one is happy with it. Pity that it does not have a timer thou.
Cheers Piet Le Roux
CRF Bloemfontein
Cheers Piet Le Roux
CRF Bloemfontein
