Fail Safe
VA
Fail Safe
Danny I have a 6102 radio im using on my raptor 30 and today i noticed that when the fail safe mode is on the throttle goes to full throttle instead of idle like it should.I put it in hold mode for now. Is there anything i can do other than move the linkage to the other side of the linkage arm and reverse the servo?? Im glad i noticed this problem before learning the hard way. Thanks
RE: Fail Safe
I assume the 6102 is being operated in a PCM mode to get fail safe. As I understand it, you have the option of it holding last good signal OR telling the servos what position to go to. Sounds like you have the throttle set to go to a known position but you haven't programmed it to be low throttle.
