9X II throttle cut reverse
Hi Danny
I set up my 9X II to have throttle cut on the snaproll switch which works fine exept it is moving in the wrong direction because my throttle channel is reversed. I tried everything I could think of to unreverse the thottle cut (like reversing the throttle curve itself) but no joy. There does not seem to be a reverse function for that switch (if there is I cant find it and it is not in the manual), there is a percentage setting in the screen where i enabled the function but it does not make any difference no matter what i set it to (positive, negative or zero value). Any help would be greatly appreciated.
Thanks in advance, Damien.
RE: 9X II throttle cut reverse
I'm not familiar with that system as we do not carry it in the US. If it has a throttle cut function in aicraft mode I'm not familiar with how it works since the US 9303 does not have that. Generally throttle cut functions in aircraft simply move the throttle trim the amount that you have the trim moved up to kill the engine without moving the trim, I do not know for sure if that is the way it works on that system or not. One option you might try is to set up the throttle cut in the throttle curve function itself.
