Jr Flight Packs & futaba servos
RE: Jr Flight Packs & futaba servos
Should work fine, we don't do any cross brand testing to verify proper operation however, so you do so at your own risk. You will need to shave the tab off the Futaba connector and bevel the corners of the opposite side of the plug. You can compare to a JR connector to see the differences.
