JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Dual batteries on 659 receiver
Reply
Old 12-30-2002, 03:20 PM
ml3456
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual batteries on 659 receiver
Danny,
In another post, someone mentioned that if you were using dual batteries, plug them in on both sided of then receiver to help protect the power bus in the receiver. What do you think? With all the giant aircraft using so many digital servos, do you recommend this?
You could plug another battery into the throttle port, but would have to mix the throttle to another channel if this could be done. Or a Y adapter could be used to plug both into the throttle port.
Keep up the great work.
mark
ml3456 is offline
Old 12-30-2002, 03:30 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It should not matter where you plug the second battery in, I actually do this in several planes myself. I like to use a voltage regulator that has a diode to prevent backfeeding from one pack to the other. If you have an open channel, you can use it, or if you wanted to, you could also use a Y harness.
dsnyder is offline
Old 12-30-2002, 03:52 PM
ml3456
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Danny,
Do you plug the batteries in next to each other, or try and space them out on the receiver if you can?
mark
ml3456 is offline
Old 12-30-2002, 06:59 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I space them out sometimes, and other times, have them right next to each other. If you can space them out, it may be slightly better, but overall it really shouldn't matter that much.
dsnyder is offline
