652 dead please help!
hi,
last night i pluged in my radio to the wrong charger,a heitc one with a tx output of 10.4v and 55ma .when i turned it on this morning i heard a pop and then nothing would happen ,the light on the jr charger still comes on when its plugged in.i checked the fuse and tested it with aa battery and a little light, the light came on so i dont think its blown,but i might be wrong are there any other fuse/things to check?...please help!!
thanks,
lee
thanks,
lee
There are a couple diodes in the transmitter that go out when it has had reverse polarity, and maybe the lithium battery could be drained. You will need to send it in for service. This is generally in the range of $40, maybe higher or lower depending on what needs to be done. Fill out this form when sending it in. http://www.horizonhobby.com/media/pd...rchecklist.pdf
