10x snap button
My Feedback: (23)
10x snap button
Is it possible to have the snap button on the 10x be changed to start/stop the timer? The snap feature is useless to me and I would like to do something with this button sitting here.
If thisis not an option, are there any other choices I may have? Perhaps chane it to a switch?
10x snap button
I'm sorry to say that the snap button can't be used for the timer, however it can be used as a switch in the program mixes. In a mix press page to get to switch selection, and there will be the option of SNP on this page, select it, and you can use it for any function you can use a mix for.
10x snap button
It depends on how you set it up. If you leave something active without the switch pressed, you could deactivate it with the switch. But if you have something active only when the switch is pressed, you would have to hold the switch down while you want the function to be active.
10x snap button
