JR "Z" PCM on 9303 - will the rx's work?
My Feedback: (10)
Good morning from Winnipeg Canada,
Will the 9303 TX work with my 910 "Z" pcm recievers.
The horizon site says only - spcm and fm
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRP9241**]horizon jr 9303 web site[/link]
cheers - ken kalynuk
Flight modes (3 air, 5 sailplane, heli)
Fail Safe system
Modulation, SPCM or FM output
Gyro System (In-flight selection of 3 gains for up to 2 gyros)
6 Programmable mixers (2 Multi-point style)
Fail Safe system
My Feedback: (91)
RE: JR "Z" PCM on 9303 - will the rx's work?
Hi Kinair.......As the transmitter, (9303) come from the factory, it will not work with the older "Z" series modulation. However, If you send it back to Horized and tell them that you want it modified so you can use your receivers with Z, modulation, They will modify it for you free of charge. I had the modify mine so I could use my receivers. Bob
