jr mixing 2 throttles
I need to set up 2 throttles for a twin and want to use a trim pot to sync the rpm on the motors (Gas engines).
If I mix the throttle channel to say the flap or aux as a slave and have a slide pot on this channel can these servos move in sync but have the ability to trimone with the other?
RE: jr mixing 2 throttles
With most systems you should be able to set up twin engine aircraft. Do you have a system currently or are you looking for a system to do this? The 9303 (and I believe the overseas 9XII) have a twin engine function pre-set in the system.
