Help!
Help!
Hi,
I have an old tx NET-J128F with an fm tx module NET-J53M at 53 mhz.
which micro rx can I use?
where can I find the meaning of switches and trimmers that are in the back of the tx?
Thanks.
Claudio (Ascoli Piceno - Italy)
Thanks.
RE: Help!
I don't know of any micro RX's on 53 Mhz, but I would recommend contacting your local JR distributor, which should be Rossi, the number I have listed for them is 39-030-252-1728.
RE: Help!
ORIGINAL: dsnyder
Some other questions.
1) My NET-J128F is configured as mode 1. Can I change it in mode 2?
2) I lost the charger. Can I use std ac/dc converter to recharge the tx battery? at what voltage?
RE: Help!
1) That is something that depends on the area, I would recommend contacting your JR service facility for information on that.
2) You would need a proper charger for the system. I would not recommend an ac/dc converter.
