JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR Receivers on 50MHz
Reply
Old 01-07-2003, 10:44 PM
napierm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR Receivers on 50MHz
Hey Danny,
What JR receivers are available on 50MHz?
Any chance of getting an R610 on 50MHz?
Also, as a HAM, can I swap the crystal in my TX module? Say from 09 to 08? Shouldn't be a technical problem, is there a legal one?
Thanks in advance,
Mark Napier
KF4MZL
napierm is offline
Old 01-08-2003, 05:01 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most all Aircraft JR receivers are, with the exception of the 610. An alternative would be to use the R700 instead, it is available on 50 Mhz, and is nearly the same size.
To change the frequency of a transmitter, it must be performed by an authorized service center, per the FCC.
dsnyder is offline
Old 02-11-2003, 11:09 PM
HalH
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can buy a 950G-10ch-S-PCM receiver that is 72MHz. Can I just change the crystal to a 50MHz crystal for use with my 10X on 50MHz?
HalH is offline
Old 02-12-2003, 01:55 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm sorry to say that you would not be able to do that. The tuning would be too far off and it would not work. You will need to get a receiver on 50 mhz.
dsnyder is offline
Old 04-24-2003, 04:33 PM
RookieII
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most all Aircraft JR receivers are, with the exception of the 610. An alternative would be to use the R700 instead, it is available on 50 MHz, and is nearly the same size.
Hi Danny,
Just to clarify, I have a 72 MHz 8103 transmitter - so I can change the frequency "MODULE" to a 50 MHz channel without issue, right?
...then pair it with a new 50 MHz receiver.
Thanks!
RookieII is offline
Old 04-24-2003, 04:45 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, that is correct. Changing the module to 50 Mhz is all you would need to do to change the tx to 50 Mhz.
dsnyder is offline
